timbo8391
Jul 19, 2020Aspirant
AX12 Won't connect to Comcast Modem
I've got a Comcast Arris cable modem and configured it for bridge mode. I connect it to my AX12 router and I get an internet light on the router so everything looks good. However, I can't connect to ...
michail71
Jul 22, 2020Apprentice
I have the same setup, XB6 modem and AX12. I was not able to get bridge mode working either. The router never got a dynamic IP assignment. Comcast support even tried helping out. They were very helpful but after failing to get it to work, Comcast gave me an account credit.
However, I'm getting much better overall WiFi out of the Comcast XB6 than I am with the AX12. So I'm debating a return. I have both APs running now. Which I need for my 802.11ac clients to even get a stable connection.
We shouldn't have to stuggle so hard getting a $500 router to work! It should be amazing out of the box.
RajaDaja
Jul 22, 2020Luminary
Sorry to here that. Have you actually used the AX12? To imply that the Xfinity gateways wi-fi is better without actually setting up your AX12 is a little bias. Well you could save over a hundred dollars a year by purchasing your own modem......
- michail71Jul 22, 2020Apprentice
Yes, not to hijack OPs thread, but we have a similar setup :), https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/Terrible-WiFi-with-RAX12-after-switching-off-Xfinity-AP/m-p/1948580#M10786
