timbo8391
Jul 19, 2020Aspirant
AX12 Won't connect to Comcast Modem
I've got a Comcast Arris cable modem and configured it for bridge mode. I connect it to my AX12 router and I get an internet light on the router so everything looks good. However, I can't connect to ...
michail71
Jul 22, 2020Apprentice
I have the same setup, XB6 modem and AX12. I was not able to get bridge mode working either. The router never got a dynamic IP assignment. Comcast support even tried helping out. They were very helpful but after failing to get it to work, Comcast gave me an account credit.
However, I'm getting much better overall WiFi out of the Comcast XB6 than I am with the AX12. So I'm debating a return. I have both APs running now. Which I need for my 802.11ac clients to even get a stable connection.
We shouldn't have to stuggle so hard getting a $500 router to work! It should be amazing out of the box.
timbo8391
Jul 22, 2020Aspirant
I think this is the problem I am having. I get everything connected up, get an internet light on the router but I don't think I get an IP. I have no idea why this is happening. I had the AX12 working just fine with a different modem. Maybe I need to switch back to my old modem and get rid of the Comcast one. I'm not even able to see the router when I try to browse to it. Comcast sees nothing wrong when they check.
- michail71Jul 22, 2020Apprentice
The problem could be on either end but it's hard to tell. I suspect Comcast firmware is the issue. We would need an engineer from either side to debug. All I can tell is that the asignments are not being negotiated between them.
- timbo8391Jul 22, 2020Aspirant
Correct. I may switch to my own modem. I doubt this will ever be resolved if we need engineers from both sides to debug it. Thanks.
