CBV
Jan 29, 2020Tutor
AX120 don't start up only blinking power light after firmware update V1.0.1.114
Today I did a firmrware update V1.0.1.114 to my AX120, after 30 minutes I went to check my router and it was not started up, only power ligh is blinkig and reset button is not working.
Any ideas on how to solve it?
Thanks
Regards
1 Reply
CBV wrote:
Today I did a firmrware update V1.0.1.114 to my AX120, after 30 minutes I went to check my router and it was not started up, only power light is blinking and reset button is not working.
An indicator of corrupt firmware. (See the manual for what the LEDs mean.)
What colour is it blinking?
Unfortunately, you are probably into TFTP territory.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
TFTP isn't the easiest of manoeuvres, so it might be worth a web search for videos that show how to do it.
netgear router tftp video - Google Search – netgear router tftp video
Take your pick.
