briandconnolly
Jul 05, 2021Aspirant
AX120 Dropping Connection
Ever since upgrading to Firmware Version V1.2.1.22, I get sporadic dropouts where I am asked to resubmit my password. Thoughts? SETUP Fedora 34 w/ Gnome 40 Smart Connect enabled Access Con...
microchip8
Jul 05, 2021Master
Try without Smart Connect. On NG routers, SC isn't working as it should in a lot of cases and NG seems to break it every now and then.
- briandconnollyJul 05, 2021Aspirant
Roger that. As a test, I turned off Access Control and rebooted. And as the issue is sporadic, I need to let it sit for a while.
I'll try your solution next, if need be, and report back.
Thanks for the prompt reply!
- briandconnollyJul 06, 2021Aspirant
You were right. Diabling AC did not fix it. Disabling Smart Connect seems to have done the trick.
Thank you!
