briandconnolly
Jul 05, 2021Aspirant
AX120 Dropping Connection
Ever since upgrading to Firmware Version V1.2.1.22, I get sporadic dropouts where I am asked to resubmit my password. Thoughts? SETUP Fedora 34 w/ Gnome 40 Smart Connect enabled Access Con...
briandconnolly
Roger that. As a test, I turned off Access Control and rebooted. And as the issue is sporadic, I need to let it sit for a while.
I'll try your solution next, if need be, and report back.
Thanks for the prompt reply!
briandconnolly
Jul 06, 2021Aspirant
You were right. Diabling AC did not fix it. Disabling Smart Connect seems to have done the trick.
Thank you!
