gyifan
Aug 14, 2020Initiate
AX120 Link Aggregation drops speed until reboot
Similar to another thread, I found the internet speed drops from 900+Mbps to ~5Mbps everyday. To fix the issue, I have to restart the router. Then the speed will come back to normal (900+Mbps).
Based on this thread discussion a year ago, I had to disable link aggregation. I'd like to check if anyone has gotten Link Aggregation to work with their AX routers.
Thanks!
