benderrodriguez
Apr 11, 2026Follower
AX1600 - new out of box - default password not working
just opened a new AX1600 (RAX5) connected the nighthawk app...and the default admin password is not working for the router. also connected to 192.168.1.1 - same issue. I am using the 'admin' user na...
Apr 11, 2026Guru - Experienced User
So if you press the reset button in back for 15 seconds then release and then connect one ethernet PC to the back of the router, and naviate to 192.168.1.1 in a web browser, can you get to the setup wizard at the bottom of the page and select don't have a mobile device then proceed to walk thru the set up wizard here?
Brand and model# of the ISP modem the router is connected too?
