wifkuri's avatar
wifkuri
Follower
Mar 20, 2025
AX1600 RAX10 LED Question
Hello!
I had a question about my netgear LEDS. Nowhere on the manual does it show this, but I was wondering..
In INTERNET LED is constantly blinking. There is no pause or buffer in it. Is this because it is syncing with my modem?
The wifi LEDS blink when traffic goes in and out (if nobody is using the wifi, it doesnt blink. if somebody is using it or doing something, it blinks a little, etc)
But the internet led is CONSTANTLY, NONSTOP blinking. Everything works fine. I just wanted too know if the nonstop blinking was normal or had something too do with its connection to the modem
1 Reply
  • michaelkenward's avatar
    michaelkenward
    wifkuri wrote:
    Hello!
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Check the section in the manual Top panel LEDs (p 11)
    Blinking green. The port is sending or receiving traffic.
    Just another user with time on their hands.
