Chris_Cuomo
Mar 12, 2024Aspirant
AX1800 - 300Mbps in, but only 100Mbps out
Windows 10, Spectrum 300 Mbps internet via ES2251 modem I've verified the firmware is up to date. I've checked the drivers. I've power cycled it and the Spectrum modem. Multiple times. I've ...
- Mar 14, 2024
Well, I've again tried resetting everything. Tried even more CAT6 cables. Disabled QOS on a co-workers suggestion. Still I get only 100 MBps.
At least when I return it, I can feel satisfied that I tried everything I could.
schumaku
Mar 14, 2024Guru - Experienced User
Chris_Cuomo wrote:
If my post showed up twice, I have no idea how that happened. I only posted it once. Here's the package of the router I received from Amazon. I wasn't really expecting a plain brown cardboard box instead of retail packaging, but wasn't too immediately concerned.
Modern eco-friendly packaging that is, and the eggs-box-like cardboard insert.
Instead looking on the packaging, what does the router itself say, model label, et all - and last but not least, the Web interface.
Somehow I'm under the impression, you got an very inexpensive router, like an R6020 instead - and not an R6700AX.
Post pictures of the effective router (both sides, including lower side view), the Web UI, ...
Have you bought a refurbished unit from Amazon? Suspect fraud ... some Amazon customer has returned an old device in an R6700AX box - and the poor or non-existing return logistics hadn't catched it.
michaelkenward
I received a Netgear modem in that sort of packaging years ago.
Maybe it is a European thing.
- schumakuMar 14, 2024Guru - Experienced User
No, the new industry de-facto standard worldwide, pretty new back at that time however 8-)
- Chris_CuomoMar 14, 2024Aspirant
- michaelkenwardMar 15, 2024Guru - Experienced User
The only recent packaging I have seen from Netgear (last year), was the "NAS" version with all the usual ecohorrors in the way of printing inks.
The "paper" insert certainly replaced plastic foam a whole back.
Making devices themselves out of bamboo rather than plastic never caught on widely.
