GJim406's avatar
GJim406
AX1800 blocking email access POP3
Netgear AX1800 RAX10
Firmware V1.0.14.134
Suddenly blocking e-mail ports 110 and 587, all other internet services are working.
I also tried previous firmware, V1.0.13.128.
No port blocking enabled.  If I bypass the router, e-mail working normally.
Thanks for any assistance.
Jim
  • michaelkenward's avatar
    michaelkenward
    Are you sure this is the router and not some on the email servers?
    ISPs love changing these without telling people.
    • GJim406's avatar
      GJim406
      It's definitely the router.  Not able to access e-mail with two different computers if the router is in the path.
      Remove the router, and e-mail works just fine from both computers.
      This issue began yesterday morning, all had been working fine since May 18th when I purchased this router.
      Ports 110 and 587 are standard for POP3 e-mail accounts, my domain/e-mail hosting service fully supports these ports.
      Jim
        michaelkenward
        A few things to check:
        • Can you see anything in the router's logs?
        • Have you tried a reset of the router?
        Before you reset, save a backup of the settings just in case it doesn't fix things and you want to revert to the old configuration.
        How do I reset my Orbi WiFi System to factory default settings? - NETGEAR Support
        If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that sits between this router and the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
        I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting. And that includes routing issues that might affect your email ports.
        This is not an issue that I have seen here before, so it might have something to do with your local settings rather than something that hits all users of this device.
    • GJim406's avatar
      GJim406
      The router is still under warranty -- should I file a warranty claim?
      Jim
        michaelkenward
        Jim
        Worth trying. If nothing else that might kick in the official Netgear troubleshooting service.
