Agentb9FollowerJul 07, 2024AX1800 bought used. Need to retrieve password. I acquired this router used. Is it possible to retrieve the password?
FURRYe38Guru - Experienced UserJul 07, 2024No. Factory reset it and setup from scratch using the reset button pressed for 10 seconds then release.
