caughtbythefuzz
Oct 22, 2020Initiate
AX1800 drops connection to certain devices
AX1800 (RAX15) sometimes drops connection to certain devices on network. Connections will work for several days and then drop. Device will then not be able to access network with following error: "Un...
Christian_R
Oct 27, 2020NETGEAR Employee Retired
Hello,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
SideRetired
Dec 24, 2020Aspirant
90 Day limit for support is unacceptable for YOUR mistake in bad programming. This constant dropout problem is a Netgear Problem, not a user error. Netgear has known of this problem since April 2020 and has done nothing to update the firmware and resolve. It's too late to get my money back. Will be buying a Linksys router instead.
