mhmoran
Feb 01, 2025Aspirant
AX1800 firm fails and bricks
Got a hand-me-down RAX15 ( ax1800 ) that probably had not had the firmware updated since 2020. The Android app identified it and asked for an update. The update failed with an unprovided message, e...
mhmoran
Feb 02, 2025Aspirant
||> mhmoran wrote:
|> Got a hand-me-down RAX15 ( ax1800 ) that probably had not had the firmware/>
|> update failed with an unprovided message, effectively bricking the device.
Well, in my case the definition of bricked is the lights are on, but nothing responds. It is not issuing DHCP addresses, no traffic is moving ( wired or wireless - traffic scanners see nothing from it ), and finally, the internet port doesn't light when connected to the broadband modem.
|> How did you try the update? The app us generally pathetic. Wired and manual is
|> best.
Unfortunately, I let the Android version of the app to the upgrade. I told me that the update failed and asked if I wanted to send in a crash report. I sent it in.
The manual attempt was made by trying to follow the cited article
|> How do I manually upgrade firmware to my NETGEAR Router? | Answer | NETGEAR Support
The problem I'm having is that the directions is the article do NOT match what I'm seeing ( or their definition of blinking is different from mine ). Specifically, it says to start the TFTP transfer when the power light is blinking
From the article:
9. Wait for the Power LED to light orange and start flashing.
10. When the Power LED is flashing, return to the Command Prompt app and press Enter to execute the tftp command and initiate the firmware upload.
The problem I'm having is that the Power LED NEVER flashes. It goes from solid
orange to solid white, and shortly thereafter the Internet light goes orange, followed by the WIiFi light going white. Even though port 1 is connected between a Windows matching and the router, the port light stays dark.
Thanks for the link to the video. I watched it, it says the same thing as the original article .. power light flashing to be able to connect. I never get a flashing power light.
michaelkenward
Feb 02, 2025Guru - Experienced User
The "bricked" label is widely abused, partly because it has no real technical meaning. No surprise then that your definition is at odds with the more widely used notion of busted firmware.
What do the lights actually look like? What colour is the power LED and what is it doing? Flashing or solid?
If it is "solid white" it isn't bricked in the sense that the firmware shows no sign of being damaged.
Step back and explain what you are doing. What is the router connected to? What do you mean by " port 1 is connected between a Windows matching and the router"? Machine?
You can get odd behaviour of you try adding another router to your existing router. If you can plug it into a PC with nothing else in there, what happens when you try to use a web browser and the graphical user interface (GUI)?
The bottom line may be that this is a dead router. But there are a few things that you can try to pin that down.
Just another user with time on their hands.
- mhmoranFeb 02, 2025Aspirant
|> > orange to solid white, and shortly thereafter the Internet light goes orange,|> > followed by the WIiFi light going white. Even though port 1 is connected
|> > between a Windows machine and the router, the port light stays dark.
|> If it is "solid white" it isn't bricked in the sense that the firmware shows no sign of |> being damaged.
The power light comes on initially solid orange and then flips to solid white, no flashing at all. The directions from support say to start the TFTP when the power light flashes.
|> Step back and explain what you are doing. What is the router connected to? What |> outer"? Machine?
Router is currently disconnected from everything but the windows machine being used as the TFTP host.
|> You can get odd behaviour of you try adding another router to your existing router. |> If you can plug it into a PC with nothing else in there, what happens when you try |> to use a web browser and the graphical user interface (GUI)?
The current configuration is a Win11 box with wired ethernet connecting to port 1 on the router. Wifi is light goes solid white. My wired and wireless traffic sniffers see no traffic on either ethernet or Wifi, even though both have solid white lights.
The browser is unable to connect and eventually times out, even though port 1 is lit as active to the router.
|> The bottom line may be that this is a dead router. But there are a few things that |> you can try to pin that down.
So yes, the router might be dead as nothing seems to be flowing out from it but it is still showing solid white lights on 1, 4, & 5. The Android app is telling me the upgrade from 2020-era firmware to the latest failed and a support ticket was created.
The support AI is telling me to reflash the firmware from a machine using TFTP and to only start the TFTP once the power light flashes. Unfortunately, the power light NEVER flashes. It comes on white, then goes to orange, and back to white all in about 60 seconds.
I've tried starting the TFPT on the first white to orange transition and on the return orange to white transition. TFPT never connects.So, I guess the real question is the lack of a flashing power light an indication that some bit of hardware has failed rendering the router unconfigurable.
- michaelkenwardFeb 03, 2025Guru - Experienced User
TFTP is there to mend routers with broken firmware. From your description the firmware is not bust.
You can still use TFTP to write firmware, but you do not have to use the same "catch it will you can" trick. You should be able to do it when the power LED is white:
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
There is an alternative to TFTP:
Search - NETGEAR Communities – nmrpflash
One thought is that someone has installed alternative firmware on this router. You should still be able to get into it, but you won't be able to update the stock firmware.
