KyroManiac
Dec 30, 2023Initiate
AX1800 Issue Trying to Port Forward Minecraft Server
I'm quite new with the issues of the networking but I've been doing this for years and have never seen this sort of problem. I'm living with a friend and we wanted a Minecraft server, and over the ye...
schumaku
Jan 09, 2024Guru - Experienced User
Check your R6700AX -> Internet Connection and compare the IP address shown there is the same you have in this checker with 104.145.x.x? If not, your Internet connection is some carrier grade NAT connection, and not connectable over the IPv4 IP address.
EDIT: 104.145.x.x does not look like a CGN network address, which is typically in the 100.64.0.0 - 100.127.255.255 range. So the problem is elsewhere...
