menana
Apr 02, 2021Aspirant
AX1800 Mesh WiFi 6 system firestick problem
Just purchased the AX1800 do to problems with our provide router by our ISP. We use firesticks to stream our entertainment. I installed the router and the 2 satellites and then the firestick would n...
Apr 02, 2021Guru - Experienced User
what modem/gateway is the router connected to?
What actual system do you have? AX1800 is a speed, not a model
- menanaApr 02, 2021AspirantThe model is a mk63. The modem is one supplied by our ISP Spectrum. It doesn't have a make on it.
- plemansApr 02, 2021Guru - Experienced User
some isp's supply modem/router combo devices which can cause a double nat and the occassional issue. does your modem have a model number on the label
