bkelly1369
Jun 09, 2025Tutor
AX1800 model RAX10 cannot connect wireless
Purchased the device earlier today. Log on with an Ethernet connector and configured it. There is an internet connection with the hard wired cable. It will not access via wireless. When logged in...
michaelkenward
Jun 10, 2025Guru - Experienced User
bkelly1369 wrote:There is an internet connection with the hard wired cable. It will not access via wireless.
What will not "access via wireless"?
Do you mean that your wifi devices will not connect to the RAX10?
What happens when you try?
bkelly1369 wrote:Right now, with a cable connected, all the display LEDs are lit. Three turn off regularly for brief periods then right back on again.
What about the wifi LED?
What modem/gateway/ONT connects the router to the Internet?
Just another user with time on their hands.
