ADIUNG92's avatar
ADIUNG92
AX1800 Rax 10
I have multiple devices that are successfully connected to the router, however, one particular laptop (running Windows 10) can not "see" it.  I'm at a loss as to why (since the laptop does display other nearby connections).  Is it something in the laptop configuration or settings in the routers that I need to look into?
  • plemans's avatar
    What wireless chip is in the laptop? some of the older drivers couldn't "see" AX signals.
    most have them have gotten updates direct from the chip manufacturer (not the laptop maker, the actual wireless card maker) that fixed it.
    • ADIUNG92's avatar
      ADIUNG92
      it has a Intel(R) Dual Band Wireless-AC 7265, but checked earlier and have the most recent driver
      • plemans's avatar
        what actual driver version are you on?
