EbjImmano's avatar
EbjImmano
AX1800 RAX10 as a wireless bridge
Can this router be used as a wireless bridge, making it connect to an existing wireless network through Wi-Fi, as a client, and provide access to that network to devices connected to its own ethernet...
  • FURRYe38's avatar
    Feb 10, 2022
    Check under Advanced tab/Advanced Settings for modes. You should see Router/AP and maybe Bridge (Wireless Bridge) if this model router supports it. Then try under Advanced tab/Advanced Settings/Wireless Settings and scroll down the page towards the bottom to see if you might see a option called "Use Other Operation Mode" maybe seen here. This would be bridge mode.
