katlou
Apr 09, 2021Aspirant
AX1800 RAX10 no remote management with this router?
I just purchased Netgear AX 1800 RAX 10 router and am unable to find remote management. I would like to make sure it is disabled. I have looked through the entire router web GUI four times and it i...
antinode
Apr 13, 2021Guru
> I just purchased Netgear AX 1800 RAX 10 router [...]
Firmware version?
> [...] I have looked through the entire router web GUI four times and
> it is nowhere to be found although the users manual shows that it should
> be in the Advanced Setup section. [...]
Are you looking at:
ADVANCED > Setup > ???
or:
ADVANCED > Advanced Setup > Remote Management
Netgear's management interface structure has some potentially
confusing quirks.
- katlouApr 14, 2021Aspirant
I have looked through the entire router several times. including Advanced>Advanced Setup> The problem is that Remote management isn't there in the list of items to select from.
