Azjhawks123
Jun 04, 2021Aspirant
AX1800 RAX10 vs. AX1800 RAX20
Hello, I recently purchased the AX1800 RAX10 dual band router. It's working fine, a big upgrade from our previous AC model, although speeds can fluctuate from time to time. Right after that, I found ...
schumaku
Jun 05, 2021Guru - Experienced User
The RAX10 is a lightly stripped RAX20 router as you already discovered, same platform, no USB port and related services.
Azjhawks123
Jun 06, 2021Aspirant
Thanks. I thought it might be something simple like that. I noticed the RAX10 is a a year newer according to the box, and has that extra antenna, but the price difference for the less stripped down RAX20 might be worth it. Just have to make a decision.
