ExWhyWhyZee
Mar 17, 2021Aspirant
AX1800 RAX15 setup as an AP, so which one's the trunk port?
How does the VLANing work on these devices? I've set the router up as an AP, and I'm going to using it in the home office, which has the PCs on one VLAN and the printer on another VLAN. Does the connected WAN port that I have connected to the existing switch do the trunking without the need for any type of configuration? If so, that's very cool, but for some reason, I don't believe it's going to be so.
Yeah, so, how does one configure trunking on the WAN or a LAN port?
1 Reply
- Christian_RNETGEAR Employee Retired
Hello,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
