Michaelcc
Dec 06, 2020Follower
AX1800 RAX20 Router WPA3 Setting issues
Dear All, I seek your help regarding the installation of WPA3 of my new AX1800 RAX20 Router. When I click http://192.168.1.1 to change my wifi setting to WPA3 - Personnel, the wife network (the ...
Christian_R
Dec 10, 2020NETGEAR Employee Retired
Hi Michaelcc,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
