SAF22
Oct 30, 2022Aspirant
AX1800 Wi-Fi 6. cannot connect to app or get online
I have had an issue since taking out of box…. Got on app… had issues… using Spectrum modem… service is for 500 speed… modem lights are on Samsung tv says connected spectrum says I am not… when I try, ...
Oct 30, 2022Guru - Experienced User
What model# router do you have? AX1800 is a wifi speed.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
