dstbal
May 14, 2023Aspirant
AX1800 WiFi 6 Router Model R6700AX as part of a mesh system
New to this whole thing, I have a 4 bedroom two story with full basement and large garage with an out building with a generator in it and the WIFI is weak in most location a friend is suggesting addi...
michaelkenward
May 14, 2023Guru - Experienced User
dstbal wrote:
I need to know what devices to purchase for use with my installed 4-Stream AX1800 WiFi 6 Router Model R6700AX. Router locate on first floor..
Never one of Netgear's most capable routers. Seems to be a variant on something launched nearly a decade ago with WiFi 6 bolted on, a feature that is useless unless you have wifi clients that have that technology.
As microchip8 says, may not meet your needs.
You may not need Mesh. But that is down to your budget and the number of users.
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
and
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
