microsvc2
Dec 20, 2021Tutor
AX20 Rebooting at random
Lately my RX20 has been rebooting at random. Yesterday it rebooted 2x. Anyone know the cause of this?
microsvc2
Dec 21, 2021Tutor
FURRYe38 wrote:What Firmware version is currently loaded?
Firmware. Here's the issue. Currently on FW 1.0.2.54. When I updated to the next version 1.0.2.82, it broke the USB LED which I need to use. So I reverted back to the previous FW. I spoke directly to a engineer in Tiawan and he verified this issue and said it would be fixed in a "future version". Since I dont see anything about the USB LED in any release notes, I have not updated. Nobody in this forum can tell me if it's working in the latest 1.0.4.100. Can you?
There is slight wifi from neighbors. I do not line in an apartment type complex, I'm in a single family home on an acre, so neighbors are not that close.
I have Spectrum internet and modem provided by them #E31N2V1 - DOCSIS
Thanks!!!
Bob
microsvc2
Jan 03, 2022Tutor
Any suggestions?
Greatly appreciated!
- plemansJan 03, 2022Guru - Experienced User
suggestions?
Make a backup of your current configuration and try the update. Not that many of the forum members who participate have that specific model.so all you can do is try it and see what happens.
If it makes things worse for you, then you can downgrade and restore the configuration
- Retired_MemberJan 04, 2022
- microsvc2Jan 04, 2022Tutor
CPU cores not shown on mine
