darnyanke
Feb 16, 2021Aspirant
AX201 Limited to 802.11a with R8000P Router
Greetings, I have a new ASUS G712LWS laptop that uses an Intel AX201 Companion RF Module using CNVio2. It seems to be unable to connect to the R8000P router on any radio (2.4 and the two 5.0) using a...
- Feb 17, 2021
Okay, the mystery deepens. I am now connected to the R8000P router with my AX201 card at 802.11ac speeds. What fixed it is I had to enable WMM on the router on all three radios. So my question is: what about WMM would allow 802.11ac? With WMM I was stuck at 802.11a? Seems strange to me. But, I am at full speed now.
Thanks to those who offered suggestions.
darnyanke
Feb 17, 2021Aspirant
Hi, as noted before, the 20.20.0.6 version applies to the package. The actual AC201 driver is 22.20.0.3 is what is now installed. See the note from the Intel site below:
darnyanke
- schumakuFeb 17, 2021Guru - Experienced User
The wonders of Broadcom ... but no, had to enable WMM on the R9000 (with Annapurna core and Qualcomm radios) for best results, too. Can't really answer your question - as confused as you.
