rogercox
Nov 21, 2022Follower
ax2400 internet led
internet led is orange ,,, what is causing this. Cant connect anything to internet with wifi
1 Reply
Not much to go on.
AX2400 is a combined wifi speed.
What NG product are you referring too.
Might help to review the user manual to see what the LED behavior may inidcate.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
