ReynaLain
Feb 17, 2024Aspirant
AX2400 RAX30 ethernet speed on pc 100mbps
currently having issues with my ethernet speeds for my pc being capped out at 100mbps. I'm running an AX2400 RAX30 with an arris surfboard SB8200 with an 1gb plan. everything else in house runs at a...
ReynaLain
i was using my current ethernet status
i understand that i would have to update from realtek
my current firmware version for my router - V1.0.10.94_3
my modem uses docsis 3.1
model number sb8200
its just a cable modem
michaelkenward
Feb 17, 2024Guru - Experienced User
Your PC is connecting at 100 Mbps. Not really a router issue.
I have never messed around with the Realtek settings. Can't see the need.
My speed setting is for Auto Negotiation.
There is newer firmware for your router:
RAX30 Firmware Version 1.0.12.100 - NETGEAR Support
