iffireno
Dec 19, 2022Aspirant
AX2400 router will not connect to internet on setup
Hello, I bought a Nighthawk AX2400 router, and I am trying to set it up. I have downloaded the nighthawk app from the google play store. I run the app and everything works great. It detects t...
iffireno
Hello,
My model number is RAX29. This router is not replacing a router. This is the first router I am putting on my home network.
Steve
Kitsap
Dec 19, 2022Master
iffireno wrote:Hello,
Steve
Good. The sequence and timing of the following steps is important.
Power down your modem (disconnect the power cord and Ethernet cable to your router).
Power down your router (disconnect the power cord).
Connect the power cord and power up your modem. Give it ample time to go through the boot process and stabilize. The online indicator should be one of the last to illuminate. The link indicator should be dark until you connect and power up your router.
If the online indicator does not illuminate, there is no internet at your modem and this needs to be resolved with your service provider before proceeding.
When you have internet at your modem, connect the Ethernet cord between your modem and router, connect the power cord and power up your router. Give it ample time to boot and stabilize. One of the last indicators to illuminate should be your internet LED. Be patient, it may take up to several minutes for an IP address to be passed through your modem to your router.
Personally I am not fond of using phone applications to configure a router. You will be far more successful using a real computer with a web browser connected to the router via an Ethernet cable.
- iffirenoDec 20, 2022Aspirant
Hello,
Thank you for the response. What do you type into the web browser to see and change the router information?
iffireno
