iffireno
Dec 19, 2022Aspirant
AX2400 router will not connect to internet on setup
Hello, I bought a Nighthawk AX2400 router, and I am trying to set it up. I have downloaded the nighthawk app from the google play store. I run the app and everything works great. It detects t...
iffireno
Dec 20, 2022Aspirant
Hi,
Thank you for the response. How do you determine if the modem is in DHCP or bridge mode. I am new to wifi routers.
iffireno.
Hi @iffireno ,
Does cable modem assigns DHCP ip to your RAX29 or it is in bridge mode that you need to input PPPOE credential to establish your internet connection ?
Kitsap
Dec 20, 2022Master
iffireno wrote:Hi,
iffireno.
Hi @iffireno ,
Go to the top of this page to the DOWNLOADS section, put in your router model number (RAX29) and download both the installation guide and users manual. Do some reading! Netgear quit printing manuals some time ago.
If you are within the first 90 days after purchase, Netgear support is free.
