liquid64
Aug 22, 2022Aspirant
AX2400/RAX29 - hairpin/loopback NAT issue?
Just bought a new Netgear AX2400/RAX29 and updated to the latest prompted firmware (V1.0.6.74_1), but it seems that hairpinning has stopped working? I host a couple of small services on my network,...
microchip8
Aug 22, 2022Master
I've never used that feature but if yoou want to go back in firmware versions, you can get them from
https://www.netgear.com/support/product/rax29.aspx#download
Click on the big + in the left corner to expand
liquid64
Thanks for the tip. I did try going back to the oldest firmware listed on that page, and the problem still exists. As a workaround, for the time being, I figured out that it's only when the internal/external port were the same, that I'm having a problem. If the router is translating to one port to another, oddly enough, it works just fine. So, instead of listening on port 8080 internally and externally, I changed the internal port to listen on 8079, and externally left it to 8080, and it seems to work. Definitely seems like a glitch in the firmware. If I have time, I'm still considering to a factory reset, to see if that works.
