davidlwoolard
May 12, 2021Follower
AX300 Ram
I have the above listed router and really love it. My question is: How much RAM does this WIFI Router for buffering issues. I see newer WIFI routers that have 3Gigs and makes me think. Than...
- May 12, 2021
What router has 3gig or ram?
Even the RAX200 only has 1gig.
If you're referring to the RAX40 (AX3000 is a speed, not a model), it has 512mb ram.
https://deviwiki.com/wiki/Netgear_RAX40_(Nighthawk_AX4)
I never ran into buffering because of ram on a router and I've used a lot of routers. It tends to be a different reason you have buffering
May 12, 2021Guru - Experienced User
