bepbep
Jul 30, 2020Aspirant
AX3000 Bad bandwidth wireless
I have a bunch of these routers in the field. There very clunky and the software being made is a bit worse every time a new version comes out it breaks some thing else. I have had issues with DHCP , t...
Christian_R
Aug 04, 2020NETGEAR Employee Retired
Hello bepbep,
Thanks for sharing your feedback. Have you had a moment to get in contact with our support team regarding your issue(s)?
https://www.netgear.com/support/default.aspx
Christian
