Yuca
Oct 30, 2020Aspirant
AX3000 RAX 38
Just purchased and installed a new Nighthawk AX3000 RAX38 because I needed a router that would provide WiFi coverage outside by my garage. I performed a speedtest and upload was 0.53Mbps. My security...
Yuca
Thank you for your reply. The AX3000 router is installed in the living room, but there is a kitchen between the living room and fartest point of the attached garage (60 feet approximately). Based on your reply, I'm assuming that a WiFi non-wired extender would not work either.
Yuca
Oct 31, 2020Guru - Experienced User
I'm not going to say an extender won't work. It might.
Its tough to say based on the info you're giving because materials in the way can matter more than distance.
and easy test?
buy a cheap 50-100ft ethernet cable (just for testing). connect it to the modem and then the router. Then move the router to where you get usable signal. If you can get it to function with the router inside the home, an extender could work. the cable lets you move it pretty wherever you need to test coverage.
Keep in mind that the extender won't have the same speed as the router but its to check signal coverage.
