locotumbler
Aug 14, 2020Aspirant
AX3000 rax35
I have an RAX35 AX3000 router. I am having issues where every day it just decides to stop communicating with my modem. When I reboot the router and modem. First modem until all lights are on and then ...
locotumbler
Aug 17, 2020Aspirant
I have noticed that I think the router is actually freezing up and not just dropping wifi. when the dropped wifi happens and I unplug an connected ethernet cable the light does not turn off on that port.
PLEASE HELP ME FIX THIS PILE OF STEAMY CRAP!!!!
- AddisonGeekAug 19, 2020Aspirant
I have had the same issue recently, and the model shows up exactly as yours. This morning my iPad connected fine; however, upon returning home from errands, it wouldn't connect due to an incorrect password. My Galaxy S10 also had the same issue, so I rebooted the router and all is fine. I have not rolled back the firmware, so I'm curious as to whether there is a bug in the firmware, as one change I made 2 weeks ago was to enable IP6 on the WAN port through Spectrum. If there is an issue with IP6 on the WAN side, then there may be a glitch in the firmware.
