lafronte
Sep 30, 2020Follower
AX3000 RAX40 issues
Running into a number of issues with this router. First, after a number of days or even hours it stops broadcasting the SSIDs and does not even hand out DHCP leases for wired endpoints. The reb...
itsmehuey
Sep 30, 2020Luminary
If you did a search you would have realised there are TONS of threads discussing this exact issue with no resolution to be found as yet and no sign of netgear support folks even caring to do anything about it.
Reverting to previous firmware should have alleviated the daily ssid drop issues but that is far from a fix for the underlying issues that are playing the router and its firmware
