lafronte
Sep 30, 2020Follower
AX3000 RAX40 issues
Running into a number of issues with this router. First, after a number of days or even hours it stops broadcasting the SSIDs and does not even hand out DHCP leases for wired endpoints. The reb...
MightyMouse2099
Nov 18, 2020Tutor
I had multiple issues with this as well. Support is no help and they only want to send you the same model in which you will continue to have issues. This router is the worst and I wish Netgear would own up to it and replace it. Maybe this is a class action worthy?
- itsmehueyNov 18, 2020Luminary
MightyMouse2099 wrote:...Maybe this is a class action worthy?
as frustrating as it's been, I don't think so. But if you plan on doing it, good luck with that.
