lafronte
Sep 30, 2020Follower
AX3000 RAX40 issues
Running into a number of issues with this router. First, after a number of days or even hours it stops broadcasting the SSIDs and does not even hand out DHCP leases for wired endpoints. The reb...
JCSooner
Nov 23, 2020Tutor
I posted on this topic, as I had similar issues. It appears to me to be a DHCP Services issue and i am not certain when or if NG can get it corrected. Mine crashed at least once a week, with a major failure only once....as I replaced it with a dedicated router and dedicated wifi...I gave up on the RAX40. I simply didn't have the time to constantly trouble-shoot a failed design and then when you want NG to help you with their failed design, they want to charge you. It's crazy!
