duaneklotz
Jun 17, 2020Guide
AX3000 stops broadcasting Wifi RAX35
This is a RAX35 but only the RAX40 is listed in the Model listing. I purchased a Nighthawk AX3000 about 4 months ago. 6 weeks ago it stopped broadcasting Wifi but the Ethernet ports to the internet...
justa4door
Jun 27, 2020Initiate
also having type of issue updated 6/26/20- my main issue is my router no longer allows traffic trough ports. I can no longer direct connect. my ISP traffic is not coming in, I connected a differnet router and no issues - everything works great with a differnet older router
when I dirrect connect and try to ping - no responce and times out I have used all 4 ports , I have pinged anything and everything you can think of
I can no longer connect via desktop access with 192.168.8.1 (I changed it ) also tried all connections thinkging it changed . no luck. tried www.routerlogin.net .. nothing .. only way I can connect is via the phone app. when I use the phone app it says its offline and no traffic is coming from my ISP, it shows no data has been sent or recieved
Im not able to do the manual connectin to 'downgrade' the firmware - when I reset it from the back it just resets all my passwords and user names
does anyone have a way to flach with the phone app?
cbondre
Jul 13, 2020Tutor
I am facing the same exact issue with RAX35 (AX3000) since i last upgraded the firmware a month ago. The WiFII keeps dropping off every day or so.
