duaneklotz
Jun 17, 2020Guide
AX3000 stops broadcasting Wifi RAX35
This is a RAX35 but only the RAX40 is listed in the Model listing. I purchased a Nighthawk AX3000 about 4 months ago. 6 weeks ago it stopped broadcasting Wifi but the Ethernet ports to the internet...
cbondre
Jul 13, 2020Tutor
I am facing the same exact issue with RAX35 (AX3000) since i last upgraded the firmware a month ago. The WiFII keeps dropping off every day or so.
internetislife
Jul 13, 2020Initiate
I ended up buying the Orbi Mesh system and it’s amazing. Haven’t had an issue. You can choose to use the older firmware if you want to reupload it. It’s available on one of the net gear posts.
