duaneklotz
Jun 17, 2020Guide
AX3000 stops broadcasting Wifi RAX35
This is a RAX35 but only the RAX40 is listed in the Model listing. I purchased a Nighthawk AX3000 about 4 months ago. 6 weeks ago it stopped broadcasting Wifi but the Ethernet ports to the internet...
achi
Aug 04, 2020Aspirant
I am also facing exact same issue since I upgraded to latest firmwire in July (Mine RAX35). I have to restart my router everytime it happens. It last for few hours or few days. Desperately looking for a patch or solution ASAP.
- Christian_RAug 11, 2020NETGEAR Employee Retired
Hello Nighthawk AX Community,
May you revert to the previous firmware version and let me know if your issue persists.
https://kb.netgear.com/000061320/RAX35-Firmware-Version-1-0-3-62
Thanks,
Christian
- MotoguzzlerAug 13, 2020Tutor
No interruptions since I rolled back the firmware upgrade and turned off automatic update. Several weeks of three to four times a day power downs restarts and now back to normal pre July performance. Two days of normal operation has convinced me that this is the issue!
- duaneklotzAug 13, 2020Guide
I have the same issue when rolling back to .62 as it powers down and restarts several times a day which is not fun when presenting on line. Interesting that the RAX40 seems to be the same machine but with a USB port. It has the same firmware upgrade versions as the RAX35. The 40 has a version .64 which fixed the problem of random resets in version .62. I think I will try the 64 firmware.
- EagleGrampaNov 06, 2020Tutor
I have rolled back the firmware as you suggested. I will (obviously) monitor the RAX35 performance closely and report back after some time.
Christian_R wrote:Hello Nighthawk AX Community,
Thanks,
Christian
- EagleGrampaNov 07, 2020TutorRolling back firmware was NOT the solution for me. It was worse. I reloaded current firmware and so far I have not reexperiwnced the problem. Not saying it’s correct but I will keep a close eye on this.
