daviddilley
Nov 15, 2021Aspirant
AX3600 Mesh will not reconnect to modem after power outage
The mesh router will not reboot and connect to modem after a power outage. Need suggestions and help
Nov 15, 2021Guru - Experienced User
1. what mesh is it? AX3600 is a speed
2. what firmware is on it?
3. what modem are you connecting to?
4. what are the led's on the router doing? (color/blinking/etc)
daviddilley
Nov 16, 2021Aspirant
Tri-band Mesh Wifi 6 System. Connects to the new Spectrum modem. After a power failure the modem boots up but the Mesh does not. The mesh has an amber light and does connect if I push the buttom on it to reboot.
Problem is, the Mesh Wifi is at our summer residence and I am 1,500 miles away. I have a friend that is going to go in and plug it into a UPS to see if this helps
- plemansNov 16, 2021Guru - Experienced User
daviddilley wrote:
Tri-band Mesh Wifi 6 System.-----Still doesn't tell us which model. There's several models.
Connects to the new Spectrum modem. ---again, still not a model.
After a power failure the modem boots up but the Mesh does not. The mesh has an amber light and does connect if I push the buttom on it to reboot. ---some devices are more sensitive to the order in which they need to be booted. Some need the modem booted for a couple minutes before you boot the router.
Problem is, the Mesh Wifi is at our summer residence and I am 1,500 miles away.----that is a bit of an issue I have a friend that is going to go in and plug it into a UPS to see if this helps---certainly might be your best option.
- daviddilleyNov 16, 2021Aspirant
If I pulg the router into a UPS so it does not have to rebooted, will it reconnect to the modem once it reboots?
Plug both the modem and the router into the UPS.
Most power failures are pretty short and the modem shouldn't pull much power.
