mjz
Dec 31, 2019Apprentice
AX4 - RAX35 How to enable led "blinking"
I tried setting the LED lights on my router to "enable blinking" to show traffic, but there is no such setting on this new router? There are only two options - turn off all leds or disable blinking....
mjz
Jan 02, 2020Apprentice
Click on link below to see screen shot of LED settings page:
https://www.dropbox.com/s/bfv7jhnlq3zrh0f/Capture.PNG?dl=0
Christian_R
Jan 03, 2020NETGEAR Employee Retired
Mjz,
Thanks for providing a screenshot. I have sent you a message.
Christian
- mjzJan 03, 2020Apprentice
I replied to your message.
Interesting that there is no way to enable LED blinking.
- JavaOopsJun 24, 2020Aspirant
No Option for RAX35 above ..... Interesing that the only options are disable blinking lights and disable lights. Those should be check boxes and not bulleyes. I wanted to see that there is traffic at a glance, but no option to enable the LED blinking feature.
- mjzJun 24, 2020Apprentice
I had assumed a future firmware update would correct the design error. My other Netgear wi-fi routers have this option working where I can see at a glance network activity when I want to have it activated.
Negear: Please fix this problem on the RAX35 ! Thanks
