larrysfishingse's avatar
Apr 10, 2023
Ax4200. Rax43
Specification says it will run on WPa3 I switched it on the router page and nothing works
  • FURRYe38's avatar
    WPA3 depends on your client devices supporting WPA3. If they don't then they won't connect if the router is set to WPA3. If WPA2/WPA3 is available try that mode. If not, you'll need to set WPA2/AES only.
    • larrysfishingse's avatar
      larrysfishingse
      Yeah that's what I said it back to WPA Aes I find it hard to believe that the smart TV smart cameras Bose radio nothing worked oh well that was one of the specifications selling features using the best security thanks for your help
      • FURRYe38's avatar
        Will have to ask those Mfrs if there going to implement WPA3. It will be up to them to do that.
        Enjoy.
