MKGMZN
Jan 28, 2025Aspirant
AX4300 broadcasting hidden SSID
I have AX4300 installed for about 4 years. I have one SSID for which broadcasting is NOT enabled. However, the router is broadcasting that SSID as well. I have another "guest SSID" for which broadcas...
- Jan 28, 2025
Thanks for the quick response.
I have lots of setup/configuration on this router, .e.g, IP address to MAC address mapping.
I have taken a backup yesterday.
Can I do the factory reset and then restore using the latest backup? Will that fix the issue?
Thanks!
Mike
Jan 28, 2025Guru - Experienced User
Does a Factory reset and setup from scratch change anything?
- MKGMZNJan 28, 2025Aspirant
Thanks!
Mike
- FURRYe38Jan 28, 2025Guru - Experienced User
Try the FR with out loading the backup first and see if the hidden SSID is gone, if so, then load up the back up from file.
- michaelkenwardJan 28, 2025Guru - Experienced User
That can bring the problem back to life.
Just another user with time on their hands.
Thank you. I will try this during the weekend.
