MKGMZN
Jan 28, 2025Aspirant
AX4300 broadcasting hidden SSID
I have AX4300 installed for about 4 years. I have one SSID for which broadcasting is NOT enabled. However, the router is broadcasting that SSID as well. I have another "guest SSID" for which broadcas...
- Jan 28, 2025
Thanks for the quick response.
I have lots of setup/configuration on this router, .e.g, IP address to MAC address mapping.
I have taken a backup yesterday.
Can I do the factory reset and then restore using the latest backup? Will that fix the issue?
Thanks!
Mike
Jan 29, 2025Guru - Experienced User
there's a difference from turning off the wifi on a specific band and whether the ssid can be seen or not (hidden).
What do you actually have checked off? (screensnips help)
also, having a "hidden" ssid doesn't always hide it. Its just usually hidden from a built in basic scanner (and not all of them either).
