HiPresto's avatar
HiPresto
AX4300 Outbound Firewall
Is there any way to set outbound rules either per MAC or per local LAN IP? I want to prevent my HP printer from constantly phoning home. I do not want to set a global rule for all attached devices, n...
  • HiPresto's avatar
    HiPresto
    Jun 04, 2024
    Thank you very much! On my tablet, I did not see the IP entry at the bottom of the configuration page, and thought it was a default global filter.
    -HiPresto.
