tadigiacomo's avatar
May 04, 2022
AX4300 (RAX45) as Access Point Seems to Block duckduckgo
I have an AX4300 set up as an Access Point. The main router is an AC1750 (R6400v2). When I try to access duckduckgo.com while connected to the AX4300 via WIFI the browser says it cannot be reached, a...
  • plemans's avatar
    May 04, 2022
    Try enabling IPv6. I've seen more devices defaulting to ipv6 for their first dns inquiry. maybe its causing an issue
