tadigiacomo
May 04, 2022Guide
AX4300 (RAX45) as Access Point Seems to Block duckduckgo
I have an AX4300 set up as an Access Point. The main router is an AC1750 (R6400v2). When I try to access duckduckgo.com while connected to the AX4300 via WIFI the browser says it cannot be reached, a...
- May 04, 2022
Try enabling IPv6. I've seen more devices defaulting to ipv6 for their first dns inquiry. maybe its causing an issue
tadigiacomo
May 04, 2022Guide
The R6400v2 firmware version is V1.0.4.122_10.0.95. IPv6 is disabled.
A bit of a long story, I bought the RAX45 to replace the R6400v2, then would use the R6400v2 as an access point. I come to find out that I didn't read the the RAX45 data sheet completely, or I would have learned that Netgear Smart Parental Controls are basically useless without a subscription. I use CIrcle with the R6400v2 without a subscription mainly for some content filtering. So, I left it in place as the router until I decide what I am going to do regarding a subscription. I may just have to bite the bullet. I agree, it should be the main router. Thanks for your reply!
May 04, 2022Guru - Experienced User
