tadigiacomo
May 04, 2022Guide
AX4300 (RAX45) as Access Point Seems to Block duckduckgo
I have an AX4300 set up as an Access Point. The main router is an AC1750 (R6400v2). When I try to access duckduckgo.com while connected to the AX4300 via WIFI the browser says it cannot be reached, a...
- May 04, 2022
Try enabling IPv6. I've seen more devices defaulting to ipv6 for their first dns inquiry. maybe its causing an issue
May 04, 2022Guru - Experienced User
There is a newer firmware for the R6400v2. I've seen a few issues on here about it but you can give it a shot and see if it helps. If it makes it worse, you can downgrade back to the one you're on.
- tadigiacomoMay 04, 2022Guide
I will try enabling IPv6 and give that a shot. Both devices are at the latest firmware, or at least they don't report a newer one available when I check from the admin pages. Thanks again, I'll report back what happens.
- plemansMay 04, 2022Guru - Experienced User
there is a new version on the support site.
you can find it here:
That fixed it! I enabled IPv6 on the R6400 and set it to Passthrough and was able to get to duckduckgo.com. Thanks so much! I have not yet downloaded the new firmware, but will get to that. Thanks again!
The next thing is to deal with the Netgear Parental Controls. I was pretty disappointed about that and almost returned the router, but I guess I'll have to deal with it.
